[SOLVED] AD7490 Interfacing with Microcontroller
ashad
Full Member level 6
Trento, Italy
I am facing some problem in Reading Analogue values from AD7490. I always received FF from ADC. If any one interface this ADC with 8 bit Microcontroller then please share your experience.
Thanks
It could have may reasons. How does your circuit diagram looks like? Or are you using the evaluation board?
Enjoy your design work!
Upload your circuit diagram and Code ..
Thanks for reply... The circuit is according to the data sheet ... I was confused due to arrangement of 12bit command word.
According to the datasheet 12bit command word with 12th bit MSB (write) and LSB is Coding bit. However We have 16 bit integer so I m confused that either I need to send 0x8330 command byte or 0x08333 command byte. Following is the coding for ur reference.
	unsigned int	adnum=1;
	unsigned char	dnum=0;
	union ad_cmd
		unsigned int	adint; 		// adint = adchar[1]+adchar[0]
		unsigned char	adchar[2];
	union ad_cmd adcmd1;
	unsigned int	maskint= 0xC3F0;	//0b1100 0011 1111
								//    --c--
	adcmd1.adint = 0x8330;			//0b1000 0011 0111 0000
	adnum=0;
	dnum=0;
	do
		adcmd1.adint &= maskint;
		adcmd1.adint |= (adnum<<10);	//Shifted for 10time
		SPDR = 	adcmd1.adchar[1];
		while(!(SPSR & (1<<SPIF)));  // wait until transmission is complete
		SPDR = 	adcmd1.adchar[0];
		_delay_ms(10);
		SPDR = 	0x03;
		ad7490_data[dnum]= SPDR;
		dnum++;
		SPDR = 	0x30;
		adnum++;
		dnum++;
		}while (adnum < 16);
Please post the circuit and mention which Compiler you are using. Its better if you Zip and post also the project files.
I am using AVR studio 4 and Atmega168 controller.
I don't see that you control the CS (SS) line at all which is essential for SPI operation.
You also didn't mention that you are dealing with ATmega and don't show the SPCR settings. Please come back with complete information.
Shifting out control register content left aligned in 16-Bit SPI data is basically correct.
One point clarified at least.
Reactions: ashad
    ashad
I asked you for the Circuit diagram and not the pinout of your ADC chip.
accept my apology
void	iniSPI(void)
	SPSR	=0x00;
	SPCR	=0b01011001;	//0x59
}//void	iniSPI(void)
//------------------------------Main Program ---------------
	while(1)
	   	while(!(UCSR0A & (1<<RXC0)));
		if(UDR0 == 's')
	//		while(UDR0 != 'x')
				PORTB &= ~(1 << SSADC0);
				_delay_ms(100);
				adcid01();
				ad7490_int();
	//			read_sensor();
//				adcid02();
//				PORTB &= ~(1 << SSADC1);
//				_delay_ms(10);
//				ad7490_int();
//				read_sensor();
	}//	while(1)
//-----------------------ADC initialization Routine
void	ad7490_int(void)
	union ad_cmd
//	unsigned int	maskint= 0x0C3F;	//0b0000 1100 0011
//	adcmd1.adint = 0x0833;				//0b0000 1000 0011 0111
										//    --c--
//	SPDR = 	adcmd1.adchar[1];
//	while(!(SPSR & (1<<SPIF)));  // wait until transmission is complete
//	SPDR = 	adcmd1.adchar[0];
	adnum=0;
	dnum=0;
	do
		_delay_ms(10);
		serial_write(adnum);
		SPDR = 	0x03;
		serial_write(ad7490_data[dnum]);
		dnum++;
		SPDR = 	0x30;
		adnum++;
		dnum++;
//		adcmd1.adint &= maskint;
//		ad7490_data[dnum]= SPDR;
//		dnum++;
//		PORTB |= (1 << SSADC0);
//		PORTB |= (1 << SSADC1);
}//void	ad7490_int(void);
I recevied already designed PCB in which AD7490 connected to Atmega168 controller
PB2 is connected with First AD7490 CS pin
PB1 is connected with Second AD7490 CS pin
MOSI is connected with DIN of AD7490
MISO is connected with DOUT of AD7490
SCLK is connected with SCLK pin of AD7490
Reactions: urdxg
    urdxg
According to the datasheet AD7490 requires CS as framing signal for every 16 bit read or write transaction.
That's not implemented in your code.
Reactions: ashad
    ashad
