accurate volt measurement over isolation barrier - analog please
Easy peasy
Advanced Member level 6
Melbourne
Hello all, need to measure 0 - 760VDC over an isolation boundary of 3500Vac, ideally to 1V accuracy or so,
ideally an opto circuit that doesn't drift too much ( unlikely I know given opto's )
or something else
if you know of something that works - please post
kind regards
Solution
thanks for the above comments, we are looking at the IL300-E or -F as it seems to be stable over time and temp
A first design gets better than 0.25%, which is 1.9 volts on 760 - down side is that it needs a small low temp Co. trim pot to set it exactly ...
5300Vac for 1 sec
State-of-the-art isolation amplifiers, e.g. from TI are using duty cycle or SD ADC, digital isolator and single bit DA. ISO121 is even supporting 3500 V working voltage. Is there a specific reason not to use a similar approach?
5300Vac for 1 sec
Solution
