access LAN from outside
alzomor
Advanced Member level 2
Germany
access outside lan test
Hi
I have a socket client server program in C
I have tested this program on LAN between 2 Pcs and it was working fine.
Now I am trying to test the program from out side "server on my LAN and client from internet"
I am using port 5000 so I set port forwarding on my ADSL router to forward requestes on port 5000 to the PC running the socket server application.
always I fail to connect to server from outside.
on the other hand I can't ping the network WAN address from out side
If ping from inside the LAN I get response and If I ping from out side the lan I get time out.
Finally If I run Appachi server , I can access the test website from outside!!!
So what should be the problem?
Salam
Hossam Alzomor
check website from outside lan
1st of all some router need reboot after configing port fwd
2nd check any firewall u have (xp firewall , antivirus ,............)
3rd there is many online port scanner , run ur server software , then try any of them so be sure that the port is opened
well try that and then tell me the result
    alzomor
how to check website from outside lan
Asslamo 3likom
Thanks Ahmed for your support
I was a strange behaviour of the ADSL router.
I configure the port forwarding but when I restart the router it forgot about its configuration.
I discovered that using port scan.
Now it's working fine.
Salam
Hossam Alzomor
www()i-g()org
www.eandit.com
test website outside local network
Asslamo 3likom
yes
Salam
Hossam Alzomor
