The resistors need to dissipate their power to the air, so you need ensure that there is sufficient air flow for them to run below their maximum rated temperature, or at least below the melting point of the connecting cables. You say this is a heater, if it is running hotter then 60 degrees C, then you cannot use PVC insulated cable. You might have to use glass fibre sleeving over bare copper wires to bring them out of the heater, where you then connect them to PVC insulated cables.
Frank
My friend, this is not a heater, this is power resistor in metal case. This type of resistor should be used with heatsink together, specially if you want to dissipate higher power.
That resistor dont have 15Ω he have 150mΩ. If you point on correct part link.
Max case temp is 200C, and should be keept in normal ranges.
Declared max power is only correct and can be achieved if resistor case have max 25C temp.
This is power resistor in metal case, this cannot be used as heater. For heating element use "Canthal" wire, or use heater from soldering iron 12V-24V-48V-220V, or use heater from hot air soldering station (SMD Remowrk Station).
