Markie
Junior Member level 2
hi, guys:
I am confused about the chapter 5 "Basic Opamp Design and compensation" of Martin's. he says that "SR=Veff1*wta". I think that SR is the large signal parameter, Veff1 and wta is small signal paramter, Can they soluted like that? Maybe Ic/Cc is the perfect one. (wta means unit gain bandwidth)
In page 231 "n-Channel or p-Channel Input Stage" section, it says "For a given power dissipation, and therefore bias current, having a p-channel input pair stage maximizes the slew rate. This result is seen from SR=Veff1*wta, since p-channel input transistors for the first stage have a large Veff than would be the case for n-channel input transistors(assumig similar maximum widths have been chosen to maximize the gain). ------yes, the Veff is larger, but can it sees the wta ? or it assumes that wta is constance? GB=gm1/Cc, no, I don't think so.
another question is : if used in SC circuit, they say that considered the speed, we should decrease the input parasite capacitor. Do you still use the p-channel as input stage?
thanks a lot for every answer.
