wilbert_hj
Junior Member level 1
I am designing a high speed board.LVDS bus are used in this design.
The LVDS bus signal speed is above 500MHz,so the SI problem is very important.
but my PCB have no enough room for LVDS bus trace group routing. I have to pour some GND copper plane between LVDS pairs in each LVDS signal group to control crosstalk effect.
The LVDS routes in 0.1mm width/0.15mm between differential lines. Can anyone can tell me what is the minimum value of the GND copper seperation distance?
I simply placed one GND signal line in 0.3mm in width as the seperation between differential lines(the LVDS bus signal plane is stacked between GND/PWR planes.)
Will there be any problems in my design? eager for some advice!
Thanks!
Thanks!
