Bluedot
Newbie level 3
8086 Question ?
Hi there ,
I'm interested in 8086 microprocessor and trying to figure it out , so while studying it , i found this big question which summaries every thing , i think .
" its required to use microprocessor 8086 to control the temperature of a room , the prespective temp Td = 25 , the operation of the suggested system is as follow .
if the room temp < Td , the heater will be on .
if the room temp > Td the fan will be on .
a/ Design the flow chart for the system .
b/ Design the complete system to a achieve the above requirement using microprocessor 8086 , buffers , clock generator , PPI , Fan , heater and other sensor electronic components "
I already found many documents and posts about 8086 but not a full design that can be traced and revised to really understand it .
Hope you can help .
Hi there ,
Hope you can help .
