7 Segment display pin connection for 3 phase pump water level controller
mailnehru
Newbie level 3
Chennai
I got this circuit 3 phase pump water level controller from EFY website.
I tried circuit connections in PCB and its working, fine.
Since the pin connections from driver IC's to 7 segment LED display is not clear, as circled in red color in attached file. I did't connect the display.
Please help me and give the pin connections from driver IC to 7 segment display.
HI all
Can you send the circuit in other format.It is not possible to read it
Best
Francisco
In this circuit diagram pin connections of 7 segment display mentioned a,b,c,d,e,f,g are not clear to me, I need those notations clearly.
