5V μA78L05 Question with SMD components
yursen
Newbie level 2
Hello Electronicers,
simple question, I would like to build a 5V regulator with SMD components,
as shown in the picture:
Figure 1. Fixed-Output Regulator
from the site:
https://www.ti.com/lit/ds/symlink/ua78l05.pdf
What is the type of capacitors 0.33uf and 0.1 uf I should use?
  • Tantalum Capacitors
  • Aluminum Capacitors
  • Ceramic Capacitors
thank you,
Yursen
Hi Yursen,
you can use SMD Aluminum Electrolytic Capacitors.
  • SMD Aluminum Electrolytic Capacitors.pdf
Reactions: yursen
    yursen
Any of those options will be fine - go with whatever satisfies your needs for cost/footprint/temperature requirements.
(My order of preference is 1. Ceramic, 2. Tantalum, 3. Electrolytic ... based principally on my irrational dislike of electrolytic caps for reliability/size/HF response reasons :)
Reactions: yursen
    yursen
from the site:
thank you,
Yursen
I dont think you can find 330nF or 100nF as electrolytic capacitor, these values are to small for this type of capacitor. This should be ceramic or tantal. I personaly use at least 10uF tantal or ceramic on input and 1uF tantal or ceramic on output.
Reactions: yursen
    yursen
Thank you verry much for your help
