3 V DC regulator for microcontroller power supply
ark5230
Advanced Member level 3
India
What is the commonly used 3V DC power supply to be used for Microcontrollers and similar devices requiring regulated 3V DC.
since 5v is usuall used for oyher purposes ,
a 5to3v low drop regulator is usually used .
Linear Technology has such regulators.
srizbf
15thmay2010
I don’t think there is one commonly used regulator for 3V systems, it’s personal choice and the number of devices available on the market is huge ..
On similar subject, here is an appnote from Microchip:
3V Tips ‘n Tricks
http://www.siongboon.com/projects/2006-01-08_more_circuit_schematic/3V%20Tips%20'n%20Tricks,%2041285A.pdf
Give it a read ..
IanP
:D
    ark5230
3.3 volt is highly used for microcntrollers, and 3.3 volt fixed regulators are used to regulate the same. For bieng simple, a resistor and zener combination with a transistor may also work fine.
Cheers
hai,
better u design with adjustable voltage regulators like LM317.vary the values of resistors and get the voltage whatever u want!
NOTE:VIN>(1.5 + Vout).
regards
karthikeyan
BurnOut_tesla said:
LM1117 is a good choice for fixed 3.3V (1 amp)
NO, sorry, it CAN NOT WORK! :-(
An LM 317 need min. 2V, typically 2.5 up to 3V for dropout...:cry: :cry:
You can have some output voltage, its very possible, but it will not be stabilized_its all!
You can have moderner (LDO similar_ i.e. the LM317 pincompatible LT1117) versions with i.e.1.5V Udrop_it will work, but not the traditional versions, pls do study datasheets in detail & extrems.
Greetings!
K.
