It states (along the same line as post #2): "The simplicity of the system originates mainly from the operation in discontinuous conduction mode (DCM)."
...as Easy Peasy says , DCM booster......specially with 3 line-line voltage inputs, which is 590Vpk......lot of voltage so DCM is nice, as you mightnt need much current at that high voltage...dep on your power requirement.
