3 digit PIC counter program
sendms
Newbie level 3
Hello everyone, I made a counter with 3 sectional of the schematic in attachments.On schematic is another pic, and I use the 16f76, 4MHz oscilator.Display with common cathode.
In the Basic, I got the written code and tried to adjust it to end,but i do not now how and i ask for help!
The counter is conceived to work like this: When the timer turns on dislpleju keys (ones, tens, hundreds) to set the desired number (say 100). When you've set that,when the "start" button pressed -activates the relay (portc.4) and display shows three zeros and controler "waiting" impulses with pulse from portc.0.Each impulse from portc.0,display is shows as number.(frist is 001, the second impulse on the display-002...) and so on until impulses reach to set number (in this case 100). Then relay is off,and count is stop.
"Stop" button is used to stop program- in a any time.When" pause" is pressed, the counting impuse stops, the relay is turned off until the start button is pressed again, when the counting continues counting from '"place"(number) wher a "pause" is pressed,and relay is on again.
I got seting up number code, how to do a rest of code?
Ufffffffff complicated right? Driving me insane,please help...
p.s. Sorry on my bad english!
Ones     var byte
Tens     var byte
Hundreds     var byte
CntOnes    var    byte
CntTens    var    byte
CntHundreds    var    byte
NumToShow    var    byte
KeyOnesReleased    var    bit
KeyTensReleased    var    bit
KeyHundredsReleased    var    bit
KeyOnesPressed    var    bit
KeyTensPressed    var    bit
KeyHundredsPressed    var    bit
KeyOnes    var    porta.3
KeyTens    var    porta.4
KeyHundreds    var    porta.5
CatodeOnes   var    portc.5
CatodeTens    var    portc.6
CatodeHundreds    var    portc.7
    DebCnt    con    3
    True    con    1
    False    con    0
    TRISA = 255        ' all input
    TRISB = 0        ' all output
    TRISC=%00000001
    ADCON1 = 7        ' svi digital
    clear
    KeyOnesReleased = true
    KeyTensReleased = true
    KeyHundredsReleased = true
Main:
    gosub Debounce
    gosub decisions
    NumToShow = Ones
    gosub ShowNum
    CatodeOnes= true
    pause 5
    CatodeOnes= false
    NumToShow = Tens
    gosub ShowNum
    CatodeTens = true
    pause 5
    CatodeTens = false
    NumToShow = Hundreds
        gosub ShowNum
    CatodeHundreds = true
    pause 5
    CatodeHundreds = false
    goto main
Debounce:
    if keyOnes = 0 then
      cntOnes = cntOnes + 1
      else
      cntOnes = 0
      KeyOnesPressed = false
    endif
    if cntOnes >= debcnt then
      KeyOnesPressed = true
    endif
    if keyTens = 0 then
      cntTens = cntTens + 1
      else
      cntTens = 0
      KeyTensPressed = false
    endif
    if cntTens >= debcnt then
      KeyTensPressed = true
    endif
    if keyHundreds = 0 then
      cntHundreds = cntHundreds + 1
      else
      cntHundreds = 0
      KeyHundredsPressed = false
    endif
    if cntHundreds >= debcnt then
      KeyHundredsPressed = true
    endif
    return
Decisions:
OdlOnes:
    if KeyOnesPressed = true then
      if KeyOnesReleased = true then
        KeyOnesReleased = false
        Ones = Ones + 1
        if Ones > 9 then Ones = 0
      endif
      else
    endif
OdlTens:
    if KeyTensPressed = true then
      if KeyTensReleased = true then
            KeyTensReleased = false
        Tens = Tens + 1
        if Tens > 9 then Tens = 0
      endif
      else
    endif
OdlHundreds:
    if KeyHundredsPressed = true then
      if KeyHundredsReleased = true then
            KeyHundredsReleased = false
        Hundreds = Hundreds + 1
        if Hundreds > 9 then Hundreds = 0
      endif
      else
    endif
    return
ShowNum:
        LookUp NumToShow, [$3F,$06,$5B,$4F,$66,$6D,$7D,$07,$7F,$6F], PORTB
 return
