oneoldude
Junior Member level 1
- Joined
- Aug 12, 2013
- Messages
- 16
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Location
- Florida, USA
- Activity points
- 257
I am putting together a complementary symmetry buffer using the 2N3904/06 combo. I plan to drive headphones with it.
For thermal tracking and some heatsinking, each pair will be epoxied face to face on a separate one in sq .062 alum heatsink.
Measurements have shown me that the internal chassis temp will be less than 40C.
The data sheets show R Theta JC to be 83C/W and R Theta JA to be 200C/W.
My best guess is that R Theta for the heat sink will be a bit worse than 20C/W
I can find no data re: R Theta for case to sink. But I assume the actual R Theta for each complete assembly (two transistors on one heatsink) will be somewhere between 83C and 200C. But where will it be?
So for a single transistor in free air at 40C ambient the calculator at:https://www.daycounter.com/Calculators/Heat-Sink-Temperature-Calculator.phtml shows that with an R Theta JA of 200C/W and .3W dissipation the junction temp will be about 100C. That will occur with IC of about 25 mA (more current would be better).
My first question is whether this is too high for the TO92 series.
Now if we glue the driver and output transistor pair on a 1 sq in sink and assume both will be dissipating .3W, am I headed for disaster? Or will the situation be manageable?
If I use R Theta JC of 83C/W and the assumed 20C/W of the sink then the calculator gives me 71C for one transistor and 101C for two. But this calc assumes perfect heat transfer from case to sink which is not true.
I can reduce the driver dissipation to about .15W if necessary. But I am trying to see how far I can go with these little devices.
So the ultimate question is, What is the max dissipation these pairs can stand (with reasonable life expectancy) if they are bonded face to face on a one sq in .062 thick aluminum heat sink? (I can also use a 1.25 in sq copper sink if that is a significant improvement)
Experience is the answer here and I have none with this problem.
Thanks.
Thanks.
