voso
Newbie
I have a 135mm diameter turntable for models. powered by the 28BYJ-48 stepper motor using a 5v transformer. I have set the unit to rotate clockwise at 2rpm with full 360 degree rotation.
However after turning it off and then back on It does not restart. If I press a button it then restarts at clockwise 2rpm full 360 rotation. Is it possible to make the unit restart when the power is turned back on? It is a Chinese unit and has three buttons with a circuit board which I do not understand! I am hoping it is just a matter of soldering in a jumper wire to make it restart when powered on. Due to the unit being in a display cabinet it is not feasible to press a button every time. I hope someone can help me!!!
