2.4GHZ transmitter choise?
Cluricaun
Advanced Member level 2
Hi
I need some help to getstarted with RF module/chip. I need to do this:
measure analog signals transmit the signals and it needs to be as small as possible and very low power consumtion.
Tech data..
transmit range: approx 2-3m (or less)
No of Channels to measure: as many as possible :)
Total size: minimal
Power consumption must also be minimal
bandwidth: each sensor channel need to measure freq from DC-1kHz
Any ideas where to start and what chip?
I found nRF24AP1 and think it might be a good start, any other ideas?
Thank you in advance, any help is welcome.
Cl
Re: 2.4GHZ transmitter
hi
i have tried some month back a very nice rf transmitters from linxtechnologies very small in size and transmet and very very low power consumtion
regards
Fragrance
    Cluricaun
nRF24AP1 is quite a new one, and may not easy to find support by all means..
Maybe you can consider nRF24L01, which is cheaper...
TI has another solution CC24xx and CC25xx, which is also good enough...
