sagar_eda
Junior Member level 1
hello all,
i want to implement 16qam modulator on ALTERA STRATIX II FPGA. i am getting input data serially one bit at a time. for 16qam, i need to take 4 bits at a time. these 4 bits serves as address for my LUT to get I and Q values. then i will multiply I and Q values with orthogonal signals (SINE & COSINE) generated using DDS. finally summation of these signals gives my modulated output signal. i have some doubts before starting my implementation. please clarify me.
1. my first problem was how to get 4 bits at a time from input bit stream which is coming 1 bit at a time.
(i know using shift registers, but here i need to wait for 4 clock cycles. is there any other way ? )
2. negative numbers (for 16qam : -1, -3) need to be stored in LUT. do i need to use 2's complement or any other ?
3. i' m thinking of implementing SINE and COSINE signals using DDS(direct digital synthesizer). Is it good method ?
4. how to implement multiplier ? (for multipling I and Q values with SINE and COSINE signals)
5. do i need to add any other blocks (ex-pulse shaping filter) for getting perfect output?
Thanks in advance.
Thanks in advance.
