0->5V DC translator to -6V to +6V
NICK7
Junior Member level 1
Greece
Hi I am trying to design a circuit that accepts as an input 0->5V DC from an AD converter and translates them linearly to -6V to +6V with a maximum sink/source current of 200mA, the input signal will change very slow (every 20ms or more) and the fast response time is not an issue. A have designed and simulated the attached test circuit and I am looking forward for your comments and suggestions, before I prototype the circuit in breadboard. In the simulation the circuit response is excellent but specifically I am worry about the thermal runaway of the two output transistors.
Thanks Nick
8-O
I .. worry about the thermal runaway of the two output transistors.
The worst case is @ 5V*125mA=625mW. No problem with a cool-star on each output transistor.
You can avoid thermal runaway by biasing output stage as
in B-class audio amplifier.
Look this picture
View attachment B Amp stage.pdf
You can put there even 3 bias diodes and put them in thermal connection
with Q1 and Q2 if needed.
Rb about 2.7k...10k only for bias current for Db.
Now Ube1 and Ube2 are locked together with bias current.
With 3 diodes Ube1-Ube2 is about 2.1V , that is more than safe , but
makes additional crossover distortion.
Look more info about class B amplifiers. (Google)
Regards KAK
The only thing you might have to add are some base emitter resistors for Q1 and Q2. 10K will do. This to prevent the transistor from turning due to collector base leakage currents. The base of Q2 is floating when Q1 is on and the base of Q1 is floating when Q2 is on. Biasing into class B or something alike might only be required if you have problems with cross-over distortion. Biasing into class B might need some thermal management to prevent it from running away.
Inventor(y)
Reactions: NICK7
    NICK7
Look this picture
Dear KAK I think that with your suggestion the BJTs will never conduct. But thanks anyway
Inventor I will test your proposal its seams to me reasonable
I know this circuit works.
Have made many similar kind of LOFI power amplifiers and powerout drivers
with dual power supply.
You only need to find right values for Rb resistors,
they are non critical. ( related to hfe of output BJT pair.
Check these ............
Regards KAK
Dear KAK your circuit is tested and working!! My mistake!!
Thanks Nick
