arbabar
Member level 2
hello,
i want solution of my problem kindly suggest me i m looking for it
my sensor output voltage ranged 0-30v
but controller works on 0-5v
so i use potential divider circuit and limited the voltage to 0-2.5v
as r2=430k and r1=4.7M formula = Vout={r2/(r1+r2)}*Vtotal
Vout={430k/(430k+4.7M)}*30=2.5V as vref=5v so vin(adc)=0-2.50v which mean adc value is from 0-512 ....
now i want to aad check point as
if
vmax of(0-30)v vmin(0-30V) uart Transmit
2.2 1.1 ABC
3.2 2.5 CDE
hence 16 values.....
i simply find a factor of 12. as 30/2.5=12
so for calculating equavalent value of (0-30)v in range of (0-2.5)v i just simple divide (0-30)v by twelve...
now how can i add check point on my values obeviously i must add them into adc values form 0-512 kindly help me regarding to this i m new b..
i m working in mikro c
how could i design it in editable mode so that one should easly edit it i.e vmax and vmin and transmit alphabatical value
i m using adc, uart , lcd for edition and diplay voltage range, num pad to edit values .....
if
2.2 1.1 ABC
3.2 2.5 CDE
