Signals timing in IR remote control and cell phones
seadolphine2000
Advanced Member level 3
Hi,..
I'm trying to interface my cell phone to an MCU via InfraRed transceiver. I need to know if there's a difference between the signals timing used in remote control and those used in cell phones.
I mean by signals timing, the pulse durations and their formats.
Thanks very much guys for all your help.
InfraRed with MCU
i do not think that there is a difference
it depends on the cell phone?
what is the type of your cell phone?
:p
InfraRed with MCU
Hi
as I know cell phone uses RS232 as interface protocol.
regards
Re: InfraRed with MCU
First of all, Thanks very much to all of you.
xxtigerxx,..
My phone is Z530i Sony-Ericson. But, do different cell phone brands use different protocols.? Aren't they standardized.?
budhy,..
remote control use propiertary standard, there are many kind of infra red remote control signal standard. (ie Philips RC5 protocol; Panasonic RECS-80 protocol; Sony Control-S (SIRCS) protocol)
That's why I opened this topic. I got these different protocols but I don't know if any of them is used in InfraRed cell phone communications, or there's another protocol.
Thanks again or your time and help.
Yes, they use IrDA as standard protocol.
InfraRed with MCU
budhy,..
What are these protocols?
What are the signals used to establish the connection.?
Thanks again to all of you.
Remote control IR protocol just a simple command mode protocol, but IrDA protocol is data mode protocol, can be use as IR network.
Please take a look at epanorama IR remote control pages
Would you like irDA protocol information?
Budhy,..
Yes, this is what I'm asking for.
In addition, I found this diagram in a Microchip application note(both attached). I'm wondering:
What is the part number for the "Host controller"?
Is there any equivalent for the MCP2140 or MCP215x?
Thanks again for all your help.
InfraRed with MCU
Hi
I'm not sure
but I think that host controller can be microcontroller.
MCP215x just convert pulse width to 1/4.
(because of low power consumption)
regards
hr_rezaee,..
Hi
I'm not sure
Do you mean that I can remove the MCP2140/MCP215x if power is not concerend?
What about the protocol handling? Who is responsible for initiating these protocols.?
Thanks again for your time.
InfraRed with MCU
I think IrDA is just RS-232 modulated over some high frequency carrier. I dont think you can remove the protocol handler since that is also doing the modulation and demodulation,.
You are only talking about Physical layer....but other layers are also needed in order to make your uC talk to other IrDA devices.
Look here
Hi
it depends on your case
in old systems you must use conventional rs232 pulses but in new systems
you must use new scheme.
I don't know about this.
regards
also tell me abt it, if u come to know
The "host controller" is any device that has a serial port. This can be a microcontroller or a PC.
InfraRed with MCU
Guys,...
Thanks very much for your time and concern.
I know that the "host controller" can be a microcontroller. My problem is the "Protocol Handler".
I'm asking if the MCP215x/MCP2140 can be replaced by any other chip or not.?
Thanks again for your help.
