how to design a CMOS reference circuit?
katrin
Full Member level 1
cmos reference
hello,
I want to design a CMOS reference circuit, which provide a voltage reference.
So I am thinking how can I design a bias circuit which is indepent from the temperature and so on?
site:www.edaboard.com bandgap reference circuit
have you ever tried CMOS bandgap?
Re: how to design a CMOS voltage reference circuit?
But my process doesn't provide bipolar transistors
it seems like the bandgap reference circuit always need the bipolar transistor acting as diode, is it true?
Is it possible to implement the bandgap reference circuit only with CMOS transistors?:|
I think that this web can help u
http://www.designinganalogchips.com/
u go to this side n than download the book "Designing Analog Chips" try to read it more mayb u can solve ur problem. Good Luck!
CMOS transistor worked in the sub-threshold region has the same behavior as the bipolar transistor. maybe you can use it to build a bandgap. there're also some papers on it.
I believe the CMOS process provides Diode devices. This diode can be replaced with BJT transistor in which they do the same function. If you are dealing with IBM process, you can look into it, they have explained about the diode characteristic.
try to review you spice file or technology file, to get something like paracitic BJT, lateral PNP, something.
Don't worry about it. No-matter what process you used. It can be generated.
If you used CMOS process, it can be generated by using lateral BJT.
If you used BiCMOS process, that's no problem there.
Cause it natural include BJT model.
go through the book(Cmos analog design) by philip allen. u can achieve sub 1v operation.
Every CMOS have P+/NWELL diodes. These are used to generate the kT-Basic-Cell. Most designs using a 8/1 or 15/1 diode array. The issue is that an PMOS input stage opamp is used to regulate the current so that the volatge difference in the kT-Loop is zero. If there is an offset in the PMOS pair it will be seen as voltage variation of the bandgap voltage.
If you use the P+/NWELL as lateral PNP bipolar transistor you will have a low Beta of 10 to 20 or even lower. But that mean that about 0.9 to 0.95 of the emitter current will receive at the P+ collector. That is enough to insert resistors to have a moderate gain of about 5-8. Then the device size of the PMOS input stage could be made much smaller and the bandgap voltage is less process dependend.
The process modelling and extraction in the CAD will possible forbid such circuit. But most processes have thet feature.
The CMOS process provides PNP bipolar devices.
