Migration Hi-Tech code to C18
tectona
Member level 2
Hi all,
I need ur help for migration.
I have written my code in Hi-Tech PICC18 c compiler.
Now because of some issues with Hi-Tech c compiler, I want to migrate my code in PIC C18 c compiler.
Plz, give me common take care points so i migrate my code efficiently into C18 compiler.
Thanks & Regards
Tectona
You can read the manual of C18, and be aware of the C18 compiler specifics such as include and linker files, as well as available libraries in C18.
Thanks for ur kind reply.
I required information which not mention in data sheet but gain through experience.
I read manual of C18 but there some issues when we migrate any code , like timing & some limitation of that compiler also.
This information not mention in compiler but this information got from who already work on that compiler.
So , i need ur help !!!
Regards
Tectona
There is a straitforward conversion, but you have to take care at least for followings:
1. Interrupt routines for high/low priority synthax (check code examples on microchip forum)
2. pin identifiing (for example RAx is changed into PORTAbits.RAx)
