klaszlo
Newbie level 1
Hi. I'm trying to use an MOC3021 opto triac to switch On/Off a little power supply(the 230 V side). I want to use it for direct load switch, not using it as a driver to a second triac. In MOC's datasheet it is a "warning" such that: "This optoisolator should not be used to drive a load directly. It is intended to be a trigger device only." Should i use it for direct load switch? This MOC can switch 400 V and 1 A. I only have to switch 230V and 100 mA. Any opinion? Thanks.
