johnli100
Member level 1
strong to open drain
For the pad design, we often hear of push-pull, push-up, push-down, open-drain, and open-source. Wiz on earth they are??? Why should we chose the different mode? Any reason?
Also, many time I hear of pin-strapping. What is it? Normally, we should use input pin or outout pin to do pin-strapping? How does pin-strapping work?
Is there any excellent document on these topic? Or an experter can kindly give some detail info on them.
Waiting 4 ur response ...:?:
