+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 27
  1. #1
    Advanced Member level 1
    Points: 5,813, Level: 18
    Maverickmax's Avatar
    Join Date
    Dec 2004
    Posts
    404
    Points
    5,813
    Level
    18
    ADC calculation - help
    Hi
    I have been doing a small experiment as I get the reading such as 920 from ADC channel when the input voltage is 680V. Then I get the value - 82 when the voltage is 0V.
    920 - 680V
    82 - 0V
    How to convert between 920 and 82 into 680V and 0V respectively for my code?
    So far I have done a little calculation:
    680/920 = 0.739
    so 0.739*920 will yields 680V
    but when I try to calculate 0.739 * 82 and I would expect OV but I get 60.6V
    So I have done summat wrong with my calculation. Any help would be appreicated
    Maverickmax
  2. #2
    Advanced Member level 5
    Points: 32,456, Level: 44
    Join Date
    Apr 2002
    USA
    Posts
    3,942
    Points
    32,456
    Level
    44
    volts = (ADC - 82) * 680V / (920 - 82)
  3. #3
    Points: 3,856, Level: 14
    Join Date
    Dec 2004
    Posts
    458
    Points
    3,856
    Level
    14
    Re: ADC calculation - help
    Quote Originally Posted by Maverickmax
    Hi
    920 - 680V
    82 - 0V
    680/920 = 0.739
    Maverickmax
    you can use interpolation, as the relationship (between voltage and adc value) is linear
  4. #4
    Points: 20,960, Level: 35
    VVV's Avatar
    Join Date
    Nov 2004
    Posts
    1,582
    Points
    20,960
    Level
    35
    See Echo47's answer.
    You first need to subtract the offset (82) from the reading and then divide by the slope of the characteristic.
    •   Alt13th January 2006, 01:46
      advertising
  5. #5
    Join Date
    Dec 2004
    Posts
    404
    Points
    5,813
    Level
    18
    Hi
    When I applied the equation in my codes and tested it and the most of time
    I only get the 0V when I adjust variable resistor forth and back but sometime
    I get 680V but I don't get any reading when I adjusted the votlage between
    0V and 680V.
    I exclude 680* from Temp = (adc_result[6]-82)/(920-82) and I found out that
    I only get most of the 0 and 1 only.
    Is there anything that I maybe overlook or is it summat wrong with my function prototype?
    int Voltage_measurement(void)
    	int Temp;
    	Temp = 680*((adc_result[6]-82)/(920-82));
    	return Temp;
  6. #6
    Join Date
    Dec 2004
    Posts
    404
    Points
    5,813
    Level
    18
    I still could not get any reading between 680V and 0V as I only get 0V and few 680V when I turn the variable resistor to full.
    Is it do with my code?
    Maverick max
    Let assume that adc_result[6] would be 920, the temp would return 680 which is fine. However the value less that 920 down to 1 which yields 0V. Why is that?
    Maverick Max
  7. #7
    VVV's Avatar
    Join Date
    Nov 2004
    Posts
    1,582
    Points
    20,960
    Level
    35
    The formula is correct. Are you sure that adc_result[6] is the correct value upon entry?
    To test, why not modify your code to simply return that value and see if it is changing linearly from 82 to 920 as you vary the voltage.
    Temp=adc_result[6]
    return Temp
    This should return 82~920, depending on voltage.
    If it doesn't, then you need to check the acquisition routine, hardware, etc.
  8. #8
    Join Date
    Dec 2004
    Posts
    404
    Points
    5,813
    Level
    18
    Hi
    In regard to your question, I have checked it many times as I get getting the reading from 82 to 920.
    I have another simple test by applying 920 in the equation instead of using adc_result[6] is 920 and change my code to test my calculation:
     int Temp;
       Temp = 680*((920-82)/(920-82));
       return Temp;
    Result: 680
    Then adc_result - 900
    Result: 0
    adc_result - 700
    result:0
    adc_result - 500
    result:0
    adc_result - 300
    result:0
    adc_result - 100
    result:0
    I realise it must be do with codes and I don't know why I get 0...
    You can try the code and you would probably get the same result like mine
    I changed from int to unsigned int, no effect then changed it to float - still same result
    Strange innit?
    Maverickmax
  9. #9
    Advanced Member level 3
    Points: 12,871, Level: 27
    silvio's Avatar
    Join Date
    Dec 2001
    Romania
    Posts
    716
    Points
    12,871
    Level
    27
    Why don't you try this way:
       int Temp;
       Temp = 680*(adc_result[6]-82)/(920-82);
       return Temp;
    The results of (adc_result[6]-82)/(920-82); will be zero regardless the type of Temp for value of adc_results[6] bellow 920, just because the results will always be less than 1.
    Funny enough the results will become even negative for value of adc_results[6] bellow 82.
    If you follow the echo47's advice then according with C precedence operators the binary operators found on the same level of precedence will be evaluated from left to right. Thus first () then * then /
    Thus Temp = 680*(adc_result[6]-82)/(920-82); will be evaluated this way:
    1st. (adc_result[6]-82)
    2nd. (920-82)
    3rd. 680 * results of 1st evaluation
    4th. results of 3rd evaluation divided by results of 2nd evaluation
    Now try with your Temp = 680*((adc_result[6]-82)/(920-82));
    According to the above equation, always all it's on the right of the * sign will be solved before the multiplication.
    ((adc_result[6]-82)/(920-82)) will always be less than 1 (0,99.......) for values of adc_results less than 920. That's why you get always zero !
    Hope it's clear why I removed the two ().
    •   Alt14th January 2006, 20:37
      advertising
  10. #10
    Join Date
    Dec 2004
    Posts
    404
    Points
    5,813
    Level
    18
    Hi Silivo
    I have tested the equation: Temp = 680*(N-82)/(920-82);
    where N is 920, 900, 500 etc
    The result is not what I have been looking for.
    It doesn't solve my problem....
    •   Alt14th January 2006, 21:56
      advertising
  11. #11
    silvio's Avatar
    Join Date
    Dec 2001
    Romania
    Posts
    716
    Points
    12,871
    Level
    27
    You want to say that Temp variable is still zero ?
    Or your initial request
    it's not been solved by the equation proposed by echo47 ?
    You mean "- 82" or "82" as a result for 0v ?
    What kind of ADC you use ?
    Just because you can use the differential mode operation of the A/D by biasing the A / D Vin(-) input and adjust the zero offset in order to get a code of 000000.... for 0v input. Then you can adjust the span to accomodate with the input range.
  12. #12
    Join Date
    Dec 2004
    Posts
    404
    Points
    5,813
    Level
    18
    On my inital request, I need get the reading from ADC ranging from 920 to 82 so I need to convert 920 and 82 into 680V to 0V
    So
    I followed echo47's equation such as temp=680*((adc_result[6]-82)/(920-82)); and I only get 680 when the adc_result is 920 but number below 920 down to 83, give 0. This is not what I really expect as I need the reading when any value between 919 to 83. So far I could not manage to iron the problem out yet
    MaverickMax
  13. #13
    silvio's Avatar
    Join Date
    Dec 2001
    Romania
    Posts
    716
    Points
    12,871
    Level
    27
    Which compiler you use for which micro ?
    Try this way:
       int Temp;
       Temp = (int)680*(adc_result[6]-82)/(920-82);
       return Temp;
    If in doubt cast.
    Can you tell me now the value of "Temp" for let's say adc_results[6] = 460
  14. #14
    Join Date
    Dec 2004
    Posts
    404
    Points
    5,813
    Level
    18
    Im using Keil and the microcontroller is XC161
    As I have modified my code as you requested.
    According to my calculator, the result would be approximately 307 but unfortunately the result from codes yields -6
    MaverickMax
  15. #15
    silvio's Avatar
    Join Date
    Dec 2001
    Romania
    Posts
    716
    Points
    12,871
    Level
    27
    OK change to unsigned int
    unsigned int Voltage_measurement(void)
       unsigned int Temp;
       Temp = (unsigned int)680*(adc_result[6]-82)/(920-82);
       return Temp;
  16. #16
    Points: 12,348, Level: 26
    artem's Avatar
    Join Date
    May 2003
    Turkey
    Posts
    1,350
    Points
    12,348
    Level
    26
    What is the int length of your compiler ?
    Just to ensure that even compiler bug does not affect compile code as
    volatile long int temp; // (32 bits calculation is a must as result can exceed 0xffff)
    temp= 680 * (adc_result[6]-82);
    temp = temp/ (920-82);
    and you can scale the divisor part to get unrounded result and keep source out of floating math to achieve necessary precision for your task.
    What compiler do you use and its version number?
  17. #17
    silvio's Avatar
    Join Date
    Dec 2001
    Romania
    Posts
    716
    Points
    12,871
    Level
    27
    Quote Originally Posted by artem
    YES, my apologize, I didn't think about that
  18. #18
    Join Date
    Dec 2004
    Posts
    404
    Points
    5,813
    Level
    18
    I have attached my code for you...
    the complier - Keil uVision4 IDE
    Maverickmax
  19. #19
    Join Date
    Dec 2004
    Posts
    404
    Points
    5,813
    Level
    18
    Bascially I have not optimized the codes and I followed your instruction.....
    Nothing changed
    Maverick Max
  20. #20
    artem's Avatar
    Join Date
    May 2003
    Turkey
    Posts
    1,350
    Points
    12,348
    Level
    26
    for me it seems that something wrong with your input from adc . Check it first .
    C:\Borland\projects\test2>bcc32 -IC:\Borland\BCC55\Include\  -LC:\Borland\BCC55\Lib test.c
    Borland C++ 5.5.1 for Win32 Copyright (c) 1993, 2000 Borland
    test.c:
    Turbo Incremental Link 5.00 Copyright (c) 1997, 2000 Borland
    C:\Borland\projects\test2>test
    sizeof int 4
    sizeof long int 4
    size of short int 2
    test with 32 bit integer
    result is 0
    result is 16
    result is 32
    result is 48
    result is 64
    result is 81
    result is 97
    result is 113
    result is 129
    result is 146
    result is 162
    result is 178
    result is 194
    result is 210
    result is 227
    result is 243
    result is 259
    result is 275
    result is 292
    result is 308
    result is 324
    result is 340
    result is 357
    result is 373
    result is 389
    result is 405
    result is 421
    result is 438
    result is 454
    result is 470
    result is 486
    result is 503
    result is 519
    result is 535
    result is 551
    result is 568
    result is 584
    result is 600
    result is 616
    result is 632
    result is 649
    result is 665
    test with 16 bit integer
    result is 0
    result is 16
    result is 32
    result is 48
    result is 64
    result is 2
    result is 19
    result is 35
    result is 51
    result is 67
    result is 5
    result is 22
    result is 38
    result is 54
    result is 70
    result is 8
    result is 25
    result is 41
    result is 57
    result is 73
    result is 11
    result is 27
    result is 44
    result is 60
    result is 76
    result is 14
    result is 30
    result is 47
    result is 63
    result is 1
    result is 17
    result is 33
    result is 50
    result is 66
    result is 4
    result is 20
    result is 36
    result is 53
    result is 69
    result is 7
    result is 23
    result is 39
    C:\Borland\projects\test2>type test.c
    #include <stdio.h>
    void main(void)
            volatile unsigned long int temp;
            volatile unsigned short int temp1;
            int tint;
            printf("sizeof int %d\n",sizeof(int));
            printf("sizeof long int %d\n", sizeof(long int));
            printf("size of short int %d\n",sizeof(short int));
            puts("test with 32 bit integer");
            for(tint=82; tint < 920;tint += 20)
                    temp= 680 * (tint-82);
                    temp = temp/(920-82);
                    printf("result is %d\n", temp);
            puts("test with 16 bit integer");
                    temp1= 680 * (tint-82);
                    temp1 = temp1/(920-82);
                    printf("result is %d\n", temp1);
    •   Alt15th January 2006, 03:38
      advertising
