elexhobby
Junior Member level 3
In Using Timer0 with External Clock, it is said that
The synchronization of T0CKI with the internal phase clocks is accomplished
by sampling the prescaler output on the Q2 and
Q4 cycles of the internal phase clocks. Therefore, it is
necessary for T0CKI to be high for at least 2 TOSC (and
a small RC delay of 20 ns) and low for at least 2 TOSC
(and a small RC delay of 20 ns).
Similarly, in T1CON register, you have a Timer1 External Clock Input Synchronization Control bit.
How is this synchronisation done & why is it necessary...
Kindly help
Kindly help
