student2005
Member level 3
There are two outputs at the front panel of an impulse voltage generator (IVG). One is trigger signal output (TSO, 0~12V), and the other one is the impulse voltage output (IVO, 0~12V). When the IVG releases an impulse voltage (width ~ 50us), the IVG will output a trigger signal at TSO.
The TSO and IVO are connected to the EXT TRIG input and Ch1 of Tektronix TDS3014B respectively. When EXT (see figure above) is selected and Single Sequence Button (single-shot acquisition) of the scope is activated, no signal is captured. When EXT/10 is selected and the level of trigger is set to 7V, the impulse voltage is captured.
Why EXT/10 is required in this measurement? Is the impulse voltage too high? Pls advise. Thanks.
