trashbox
The pi-section or Tee-section attenuation pad(or named attenuators) on PCB is used to smooth out any impedance bumps,and the greater the attenuation of the pad, the greater the degree of immunity to impedance changes.Furthermore, pi-section attenuator's leg resistors are equal in this case(please refer to: h**p://mrtmag.com/mag/radio_rf_attenuators_terminations/) What I can not understand is:
1)How the pi-section pad,whose leg resistors are equal,smooth out the impedance mismatch?(In fact,it is explained in the reference,but I can not see it since the lack of mentioned figures)
2)Some other articles also mentioned that the attenuation pad can act as an isolation? What is the principle?
Thanks for your comments.
