fmdepassos
Junior Member level 1
Dear all,
I use spectreRF in order to calculate circuit performances in a linux command line (i do not use virtuoso).
I am currently using a pss+pac analysis and a rapid IP3, in order to get the IP3 value. When I do so, spectreRF writes a file named pac.ip3.pac, however, the IP3 value is not available there!!
The only values available are:
VALUE
"RF dBm" "Pwr" -2.000000000000000e+01
"IM1 output V" "Pwr" 1.250615786982958e+00
"IM3 output V" "Pwr" 4.664492147525044e-01
END
How can I calculate the IIP3 value in dBm from this values?
I have seen a few threads here, but no one solved my problem!
Thank you in advance!
VALUE
END
