[moved] UCC21521 Gate driver-Bootstrap
kaanaydin
Junior Member level 1
Hi everyone,
I want to use TI UCC21521 half bridge driver to drive Sic mosfets.
In datasheet I saw a bootstrap circuit with negative bias.
In this circuit.VDD voltage is supplying two of them.now my question is that, what will happen if I put three UCC21521 in my circuit to drive 3 halfbridge ? can I use VDD voltage for all of them ?
Maybe you can share your knowledges about bootstrap mechanism.
Thank you,thats really important for me :)
VDD is referenced to VSS, so yes, you need only one VDD.
In this example, VDDB directly operating with the VDD voltage , and VDDA has a diode drop and resistance voltage drop. does it has any effects on operations ?
Go the usual way:
Check what´s your VDD voltage.
Check what´s your worst case diode voltage drop.
Then calculate worst case VDDA voltage.
Check driver datasheet for specified VDDA range.
Go the usual way:
Thank you for your kindly answer. What do you think about bootstrap topology efficiency ? I can not use bootstrap %100 duty cycle but otherwise(without bootstrap), I must use another source and that means are place and money. What do you think ?
Go the usual way:
Thank you for kindly answer. What about the efficiency of bootstrap topology ? I can not use the my circuit with %100 duty cycle but otherwise(without bootstrap) I must use another source.and thats means money and place. you should check figure 42,43,44 in datasheet
It is the typical bootstrap circuit. It can´t go to 100% duty cycle.
Why do you think you need 100% duty cycle?
