+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Member level 1
    Points: 465, Level: 4
    Join Date
    Jul 2016
    Posts
    41
    Points
    465
    Level
    problem with dspic33f UART transmitting interrupt
    Hi all,
    Here i'm facing the problem with dsPIC33f UART Transmitter interrupt..
    Before that im using via polling. then i configure Transmitter as interrupt. when im, transmitting array, only 5 character is sent. remaining characters are not sent. I dont know where is the problem and im not written full code here.
    void UART_init(void)
        // UART1 initialization
    	U1MODEbits.STSEL = 0;           // 1-Stop bit
        U1MODEbits.PDSEL = 0;           // No Parity, 8-Data bits
        U1MODEbits.ABAUD = 0;           // Auto-Baud disabled
        U1MODEbits.BRGH = 0;            // Standard-Speed mode
        U1BRG = BRG_RS232;              // Baud Rate setting
        U1STAbits.UTXISEL0 = 0;         // Interrupt after one TX character is transmitted
        U1STAbits.UTXISEL1 = 0;         //Interrupt when a character is transferred to the Transmit Shift Register
        U1STAbits.URXISEL = 0;          // Interrupt after one RX character is received;
        IEC0bits.U1RXIE = 1;            // Enable UART 1 RX interrupt
        IPC2bits.U1RXIP = UART1_INT_PRIORITY; //UART1 interrupt priority
        U1MODEbits.UARTEN = 1;          // Enable UART
        U1STAbits.UTXEN = 1;            // Enable 1 UART TX
        // UART2 initialization
        U2MODEbits.STSEL = 0;           // 1-Stop bit
        U2MODEbits.PDSEL = 0;           // No Parity, 8-Data bits
        U2MODEbits.ABAUD = 0;           // Auto-Baud disabled
        U2MODEbits.BRGH = 0;            // Standard-Speed mode
        U2BRG = BRG_MOD;                // Baud Rate setting
        U2STAbits.UTXISEL0 = 0;         // Interrupt after one TX character is transmitted
        U2STAbits.UTXISEL1 = 0;         //Interrupt when a character is transferred to the Transmit Shift Register
        U2STAbits.URXISEL = 0;          // Interrupt after one RX character is received;
        IEC1bits.U2RXIE = 1;            // Enable UART 2 RX interrupt
        IPC7bits.U2RXIP = UART2_INT_PRIORITY; //UART2 interrupt priority
        IEC1bits.U2TXIE = 1;            // Enable UART TX interrupt
        U2MODEbits.UARTEN = 1;          // Enable UART
        U2STAbits.UTXEN = 1;            // Enable 2 UART TX
    unsigned char ay[] = {'A','B','C','D','E','F','G','H','I','J','K','L','M','N','O','P','Q','R','S','T','U','V','W','X','Y','Z'};
    unsigned int z=0;
    unsigned int ab=0;
    void SendArrElement();
    int main(void)
        UART_init();
        SendArrElement();
        for( ; ; )
            RCONbits.SWDTEN = 0;        //to clear watch dog timer
        return 0;
        for(z=0; z<=25; z++)
             U2TXREG = ay[z];
    void __attribute__((__interrupt__, __no_auto_psv__)) _U2TXInterrupt(void)
        IFS1bits.U2TXIF = 0; // Clear TX Interrupt flag
    •   Alt20th September 2017, 04:38
      advertising
  2. #2
    Super Moderator
    Points: 234,575, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    40,534
    Points
    234,575
    Level
    100
    Re: problem with dspic33f UART transmitting interrupt
    Completely flawed. Either use polling without interrupts, then you need to check for free UART fifo space before writing to TXREG. Or transfer data to TXREG in interrupt.
    1 members found this post helpful.
    •   Alt20th September 2017, 05:44
      advertising
  3. #3
    Member level 1
    Join Date
    Jul 2016
    Posts
    41
    Points
    465
    Level
    Quote Originally Posted by FvM View Post
    i found there is delay problem. but i dont know how to send an array using interrupt. How to trigger manually to transmit array, once my array is full?
