Isn't it possible with Quartus programmer?
i need to access the entire board program stored in the max ii ufm memory.Don't understand what you are asking exactly. Active serial programming isn't available for MAX II, only JTAG programming. The other option is that UFM can be accessed by your own logic in user mode, using any interface you want, as long as the logic fits the MAX II resources.
Which interface to MAX II is available in your design and what do you want to achieve?
ok. how the ufm is accessed through internal logic????
MAX II flash is comprised of CFM and UFM. (configuration and user flash). Access through internal logic is only to UFM with MAX II and MAX V, CFM can be accessed only by JTAG interface.
Newer MAX 10 family has internal access also to CFM.
