esmaeil6514
Newbie level 2
Here is the Description of the issue: We have a 3-phase generator that in its standard working conditions, turning speed is around 3000 to 8500 rpm (which means that the output frequency is around 50 Hz to about 140 Hz). The manufacturer states that the output voltage (phase to phase) is between 35 and 95 V AC depending on speed and 300 W output power is guaranteed even in 3000 rpm without decreasing in voltage level. I want to build a regulator for this generator that be able to give me 30 V DC - 10 A (300 W). The simple solution is using a 3-phase rectifier and a buck regulator. But this solution is two main drawbacks:
The first is for 10 A I would have a 10 A * 1.4 V = 14 W loss just in rectifying circuit and for 90% efficiency I can have total of 30 W in losses. So 14 W its just a lot.
The second is in the case of 95 V AC I would have almost 127 V DC after rectifing! And no ready to use ICs like LM2596 and common buck controllers can handle such voltages.
My primary solution is using 6 MOSFETs (instead of a 3-phase-diode-bridge) like inverters used to control speed of induction motors. And get 30 V DC right after them.
