[moved] Uncertainty on generated clock and extra margin
mepriyasingh
Member level 2
1. What will be the uncertainty value at the generated clock, will it remain same or more than the master.
2. What is the exact significance in "extra margin" in set_clock_uncertainty" (fairly confusing)?
these terms are always vague. uncertainty, to me, in a physical synthesis context, means variation in the external clock source.
1) same, but often actual timing is worse because of min/max variation on the clock path that is longer than the master by at least a few gates
2) I think you are hinting at a safety margin that most designers will add on their own. a few picoseconds here and there to account for some modelling inaccuracy.
2) I think this "Extra margin" might be more than "safety margin".
where exactly are you getting this extra margin from? my tool of choice says the following about the command:
set_clock_uncertainty uncertainty_value [-setup] [-hold] [-rise | -fall] { {-from | -rise_from | -fall_from} clksig_from_list {-to | -rise_to | -fall_to} clksig_to_list | pin_or_clock_list }
My "Extra margin" term concern with:
uncertainty_value = skew + jitter + "Extra margin".
Probably makes sense in a synthesis context ; 'extra margin' might help downstream stages like CTS/PnR to meet timing with less effort.
In case of 1) wouldn't the rise-to-rise uncertainty become 2x when you have div-by-2 clock ?
No, it is proportional to the clock path length, not the division factor.
