oAwad
Full Member level 2
Hello all,
I'm trying to use the Nano-CMOS customizable model generator (URL:http://ptm.asu.edu/) to generate 45nm NMOS and PMOS transistor models with 0.1V threshold voltage. However, when I specify Vth=0.1V (and keep all other variables as default), I get this graph (see attached picture) which shows Vth way far from 0.1V and when I open nominal model I find Vth0=0.411
If someone used this generator before, I have some simple questions:
1) In attached picture, Vth has two input bars...does the second bar defines the undefined region between high and low...or they're just two ways of inputs (one for volts and one for milli-volts) ?
2) Can I decrease threshold voltage to any value or there is a minimum value ?
3) Can anyone tell me/give me some references to know how these variables affect threshold voltage, setup and hold time of transistors ?
