VHDL - native log2 and ceil for value 1
shaiko
Advanced Member level 5
Hello,
Using the combination of log2 and ceil - one can determine the vector length to store n number of addresses.
number_of_bits := integer ( ceil ( log2 ( real ( number_of_addresses  ) ) ) ) ;
But this works well only when "number_of_addresses" is equal to or greater than 2.
For the number_of_addresses = 1 - The above fails and returns number_of_bits = 0.
Which is wrong - because to represent one address you need one bit...
Of course I can write a custom function to solve that, but for the sake of having fun - I decided to avoid that.
Do you have an I idea how to tweak the above to solve the case for the value: 1 ?
Why not this?
if number_of_bits = 0 then -- or -- if number_of_addresses < 2 then
number_of_bits := 1;
end if;
Because this implies a custom function.
