+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Full Member level 6
    Points: 2,178, Level: 10
    Join Date
    Mar 2015
    Posts
    374
    Points
    2,178
    Level
    10
    Controlling 3000W heater using Triac.
    Hi all...
    i am making a small project where i need to just ON and OFF 3000W heater using a triac and 89S52.
    attaching a circuit diagram. Kindly request you to please check the circuit and components and let me know if any changes have to be made.
    as i need to play with high current, so before putting it into use i need to reconfirm and check if the circuit is perfect.
    •   Alt17th February 2017, 06:07
      advertising
  2. #2
    Points: 8,138, Level: 21
    Easyrider83's Avatar
    Join Date
    Oct 2011
    Tallinn, Estonia
    Posts
    1,461
    Points
    8,138
    Level
    21
    Re: Controlling 3000W heater using Triac.
    Current throu led should be limited. Add resistor between optocouple and transistor.
    Love me or hate me. All infractions will be ignored.
    •   Alt17th February 2017, 08:11
      advertising
  3. #3
    Super Moderator
    Points: 54,796, Level: 57
    Achievements:
    7 years registered
    Awards:
    Most Frequent Poster 3rd Helpful Member
    Join Date
    Apr 2014
    Posts
    11,081
    Points
    54,796
    Level
    57
    There are ready to buy isolating solid state relays.
    Use one with zero cross acting.
    Klaus
    •   Alt17th February 2017, 08:34
      advertising
  4. #4
    Full Member level 6
    Join Date
    Mar 2015
    Posts
    374
    Points
    2,178
    Level
    10
    Quote Originally Posted by Easyrider83 View Post
    Thanks...
    One more thing i would like to ask... That when the triac is kept off.. i mean when the heater is off... Will some amount of current will flow through the triac, or it will be completely off...
  5. #5
    Join Date
    Oct 2011
    Tallinn, Estonia
    Posts
    1,461
    Points
    8,138
    Level
    21
    Yes, there will be some small current. If you care about human body protection, mechanical relay will be better option.
    •   Alt17th February 2017, 08:57
      advertising
  6. #6
    Advanced Member level 5
    Points: 13,016, Level: 27
    schmitt trigger's Avatar
    Join Date
    Apr 2013
    C4E4DEEEDCE6ECD2
    Posts
    2,200
    Points
    13,016
    Level
    27
    Since you are not using a snubber, the leakage current will be very small....but the circuit could still give you some tingles.
    A mechanical relay, as advised previously, will completely cut off the power.
    My batteries are recharged by "Helpful Post" ratings.
    If you feel that I've helped you, please indicate it as a Helpful Post
  7. #7
    Super Moderator
    Points: 239,549, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,502
    Points
    239,549
    Level
    100
    If not a ready-made solid state relays, you'll use zero switching MOC3041 instead of MOC3021 with your triac.
  8. #8
    Banned
    Points: 5,417, Level: 17
    Join Date
    Jun 2016
    Posts
    1,159
    Points
    5,417
    Level
    17
    Use MOC3063 zer crossing optotriac. No need for a transisitor at the input side of the opti-triac. Can be directly driven with micrcontroller with a current limiting resistor.
