[SOLVED] FG-01 Antenna analyzer (YouKits) missing IC
Rahul_d
Junior Member level 3
USA
Hi All,
just bought a non working Antenna Analyzer model FG-01, (made by YOUKITS) & after opening found out that the IC4 is missing
see attached photo.
If anybody can help me in identifying this IC & the source to buy the same
Thanks in advance.
Come back after findings from the manufacturer answers.
Did you follow the traces to the absent IC to check if has to do with external/internal battery operation circuitry option ? Post a sketch of the circuitry traced from observation.
The missing IC4 circuit seems to be a MMIC amplifier.
The signal output of the IC3 (MAR04) it goes to C9, and from there to IC4 input.
IC4 is DC supplied through the L3 inductor (choke), and its output goes to C7.
From C7 the following circuit looks like a detector.
Anyway, seems that your analyzer needs that missing IC4 circuit, otherwise would be more useless components on the board.
Thanks a lot FvM, that's a great help, I will check on getting this IC.
I bought the IC through Digikey & The antenna analyzer is back in action, Thanks again all & Special thanks to FvM
