mw_rookie
I want to use a pair of LVDS line to drive a single ended control line. The control line is used just to enable/disable an IC.
Enable is when driven above 2V, ideally 3.3 V.
I understand that LVDS has a current output and also needs a DC termination in this case. I was thinking of parallel termination and have come up with the scheme in the picture. Will this work?
Thank you for reading.
