+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Member level 3
    Points: 869, Level: 6
    Join Date
    Jul 2014
    Posts
    55
    Points
    869
    Level
    Capacitor across transformer primary
    Does anyone have an opinion on why C19 is present in the attached DCM flyback schematic.
    Its a bit from this TI demo board.
    http://www.ti.com/lit/an/snva465a/snva465a.pdf
    I was thinking its just a snubber but why do that instead of an RCD snubber. Surely its going to be more lossy?
    Unless its for some parellel resonance effect?
    Click image for larger version.
Name:	LM5021 Flyback.PNG
    Last edited by BradtheRad; 9th January 2017 at 22:52. Reason: Removed duplicate image
    •   Alt8th January 2017, 19:47
      advertising
  2. #2
    Member level 1
    Points: 540, Level: 4
    Join Date
    Mar 2016
    Posts
    37
    Points
    540
    Level
    Re: Capacitor across transformer primary
    Snubber capacitor
    it's not for resonant, because of D3,D4
    it's valuse about 1/10 of reosnant frequency for L,C
    regards,
    To do it right, just read, read again, do it.
    •   Alt8th January 2017, 19:58
      advertising
  3. #3
    Super Moderator
    Points: 55,084, Level: 57
    Achievements:
    7 years registered
    Awards:
    Most Frequent Poster 3rd Helpful Member
    Join Date
    Apr 2014
    Posts
    11,139
    Points
    55,084
    Level
    57
    I don't like the direct connection of a capacitor on a mosfet switching signal.
    I think a 10 Ohms series resistor is useful.
    Klaus
    •   Alt8th January 2017, 20:35
      advertising
  4. #4
    Member level 3
    Join Date
    Jul 2014
    Posts
    55
    Points
    869
    Level
    Thanks for the replies guys.
    Anyone know what the losses associated with this would be.
    Off the bat I'm thinking that C19 is charged to have Vin across it whilst The FET is on. When the FET is turned off the capacitor will be rapidly discharged to the difference between Vin and the zener clamp (dissipation in the zener clamp there).
    After that at some point (when Isec falls to 0) C19 will be fully discharged.
    So do I just assume that the loss could be 0.5CV^2 multiplied by the switching frequency. Where C is the C19 value and V is Vin?
    Also in a DCM flyback the FET on loss is assumed to be zero as there is no change in current. Will C19 change that?
    Cheers
  5. #5
    Member level 3
    Join Date
    Jul 2014
    Posts
    55
    Points
    869
    Level
    Can anyone help?
