+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Points: 121, Level: 1
    Join Date
    Nov 2016
    Posts
    Points
    121
    Level
    Three phase power supply circuit for three phase power meter
    can anyone suggest me a simple power supply circuit for three phase energy meter. the meter must be able to operate from any single phase when other phases are off.
    •   Alt6th January 2017, 08:48
      advertising
  2. #2
    Super Moderator
    Points: 57,561, Level: 58
    Achievements:
    7 years registered
    Awards:
    Most Frequent Poster 3rd Helpful Member
    Join Date
    Apr 2014
    Posts
    11,719
    Points
    57,561
    Level
    58
    Re: Three phase power supply circuit for three phase power meter
    I assume nobody can design a circuit without any specifications.
    Klaus
    •   Alt6th January 2017, 09:03
      advertising
  3. #3
    Full Member level 6
    Points: 2,698, Level: 12
    Join Date
    Sep 2013
    Posts
    322
    Points
    2,698
    Level
    12
    Click image for larger version.
    Please select DC to DC converter based on the line voltage and required voltage for energy meter
    •   Alt6th January 2017, 09:31
      advertising
  4. #4
    Join Date
    Nov 2016
    Posts
    Points
    121
    Level
    Quote Originally Posted by KlausST View Post
    Klaus
    hi,
    I want to measure three phase voltages through a micro-controller, i need 12V/2Amp input supply to my motherboard. i have decided to give the power supply from any one of the incoming three phases, say 'R-phase". whenever R-phase goes off, a intermediate circuit should transfer the power supply to other phase. so, my controller always stays ON.
    Quote Originally Posted by smijesh View Post
    hi,
    could u explain about this circuit like what kind of component i have to use.
  5. #5
    Full Member level 6
    Join Date
    Sep 2013
    Posts
    322
    Points
    2,698
    Level
    12
    You are not specified the 3 phase voltage
    Assume 320V line to neutral
    You should select 1A 1000V diode (three numbers )
    https://potentiallabs.com/cart/in400...FYUfaAodd6kHMw
    and
    an SMPS 230V to 12V@2A
    http://www.ebay.in/itm/111875814788?aff_source=Sok-Goog
    Hope it is helpful to you !!!
    •   Alt6th January 2017, 12:25
      advertising
  6. #6
    Advanced Member level 5
    Points: 13,342, Level: 27
    schmitt trigger's Avatar
    Join Date
    Apr 2013
    C4E4DEEEDCE6ECD2
    Posts
    2,245
    Points
    13,342
    Level
    27
    Is your AC source a 4 wire, withe wye connection?
    Or is it a 3 wire, delta connection?
    My batteries are recharged by "Helpful Post" ratings.
    If you feel that I've helped you, please indicate it as a Helpful Post
