+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Newbie level 1
    Points: 16, Level: 1
    Join Date
    Dec 2016
    Posts
    Points
    16
    Level
    what is the (temp) refereed to?
    % Array storing theoretical value of Pf for AND logic decison rule
        PfAND = [];
        % Array storing simulated value of Pd for AND logic decison rule
        PdSimulAND = [];
        % Array storing simulated value of Pf for AND logic decison rule
        PfSimulAND = [];
        NormalizedThrptAND = [];
        for k=1:1:length(tau)
            % Number of samples in the sensiing duration
            N = ceil((Fs/T)*tau(k));
            PftheoryOR = 0;countsOR = 0;countnOR = 0;
            PftheoryAND = 0;countsAND = 0;countnAND = 0;
            for j=1:1:NMonteCarlo
                % Generating Random Data
                Data = randint(1,N,4);
                % Modulated signal
                mod_sig=pskmod(Data,4);
                % Finding Epsilon for this frame
                h = ones(M,1);
                % AWGN Channel
                N0 = 1/(10^(AvgSNR/10));
                Tyis = zeros(M,1);
                Tyin = zeros(M,1);
                % finding the decision statistic
                for f=1:1:M
                    Noise = sqrt(N0)*((randn(1,N)+sqrt(-1)*randn(1,N))/sqrt(2));
                    Tyis(f) = sum((abs(h(f)*mod_sig + Noise)).^2)/N;
                    Tyin(f) = sum((abs(Noise)).^2)/N;
                end
                %------------------------OR------------------------------------
                % Finding the epsiloon for OR decision rule and then finding
                % the net probability of false alarm
                Pdi = 1 - (0.1)^(1/M);
                epsilon = zeros(M,1);
                for f=1:1:M
                    epsilon(f) = ((qfuncinv(Pdi)*sqrt(1+2*abs(h(f))*abs(h(f))*10^(AvgSNR/10)))/(sqrt(N)) + 1 + abs(h(f))*abs(h(f))*10^(AvgSNR/10))/10^(AvgSNR/10);
                end
                for f=1:1:M
                    if(Tyin(f)>epsilon(f))
                        countnOR = countnOR + 1;
                        break;
                    end
                end
                for f=1:1:M
                    if(Tyis(f)>epsilon(f))
                        countsOR = countsOR + 1;
                        break;
                    end
                end
                temp = 1;
                for f=1:1:M
                    temp = temp*(1 - qfunc(((epsilon(f)*10^(AvgSNR/10)) - 1)*sqrt(N)));
                end
                PftheoryOR = PftheoryOR + (1 - temp);
    •   Alt19th December 2016, 11:27
      advertising
  2. #2
    Advanced Member level 5
    Points: 20,350, Level: 34
    barry's Avatar
    Join Date
    Mar 2005
    California, USA
    Posts
    3,926
    Points
    20,350
    Level
    34
    Re: what is the (temp) refereed to?
    We need a much vaguer post. Please don't include any important information like what language you're using, what you're expecting and what the actual problem is.
