Problem with correlation between two signals
jakjoud
Full Member level 2
Marrakech
Hi everybody,
I've got a serious problem, here is it: I have two signals u and v, I wanna measure the lateness ( time to fly) Δt, where v(t)=exp(jβ)u(t+Δt), so normally I've just to make a correlation between them and then search the max of this function f and f(Δt) = fmax, but it's not true I don't know why? am I wrong
So please could you help me!
Re: correlation problem
exp(jβ) is just a constant and the complex correlation of v(t) and u(t) should give Δt. I find no problem in cocept but the issue may be with the implementation of correlation.
brmadhukar
Correlation function may have set of local extremums each of them is less than absolytely extremum. You should look for that extremum but not locals.
correlation problem
in fact the problem could not be with the extremum, 'cause I'm working with pulses which means that the signals are finite.
And the amplemantation of correlation does'nt present a problem too, I'm working on MATLAB so it's just a function to use xcorr;
here is another real problem, in correlation of the two signals may I do xcorr(u,v) or xcorr(u,conj(v))?
thanks a lot
Hi, jakjoud
I'm not sure what you mean.
You said
"search the max of this function f and f(Δt) = fmax, but it's not true"
Maybe you can seperate input to I/Q, and make correlation by oneself. Then take a (abs(I+Q*j))^2. You can see the peak.
At last, I should remind you, the peak appear position is different base on using "conv" or "xcorr".
"xcorr" will extend the shorter vetor length to match longer one first.
"conv" makes the result length to "input1 + input2 +1". You still can use "conv" to implement "xcorr". ^_^
dreamshower
correlation problem
hi,
for me it's all over, it was just a problem of periode, it means that I must write that Δtr=Δtm-n*T where Δtr is the Δt wanted Δtm is the Δt measured and T is the number of samples in signals n is a factor appropriated, ok thanks for everybody.
let your heart still be
i need book about it
