+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Newbie level 1
    Points: 19, Level: 1
    Join Date
    Dec 2016
    Posts
    Points
    19
    Level
    DVD Stepper motor thread.
    Hi everybody. I have a stepper motor from an old DVD rom unit, which has 20 steps per turn. The thread bar for linear movement has 3 MM. of advance per turn, which results in 0.15mm of advance per step, 0.01875mm with 1/8 micro stepping by using the A3967 driver. My question is, how is that possible if distance between tracks in a dvd disc is less than 1 micron (<0.001mm)? And how can I get that displacement of 1 micron? Hope any of you could help me. Thank you very much in advance.
    Best regards
    •   Alt8th December 2016, 20:47
      advertising
  2. #2
    Super Moderator
    Points: 241,468, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,921
    Points
    241,468
    Level
    100
    Re: DVD Stepper motor thread.
    CD and DVD drive are using a combination of coarse radial positioning by the stepper motor and fine positioning by an electrodynamic drive (coil + permanent magnet). A second electrodynamic drive is moving the lens up and down to adjust the focus.
    1 members found this post helpful.
    •   Alt8th December 2016, 22:58
      advertising
  3. #3
    Super Moderator
    Points: 57,561, Level: 58
    Achievements:
    7 years registered
    Awards:
    Most Frequent Poster 3rd Helpful Member
    Join Date
    Apr 2014
    Posts
    11,719
    Points
    57,561
    Level
    58
    And the code on a CD is self-clocking, I assume on the DVD, too.
    Therefore the code itself tells where a data bit is located. No need for very precise mechanical positioning/timing.
    Klaus
    •   Alt9th December 2016, 02:07
      advertising
  4. #4
    Advanced Member level 5
    Points: 11,798, Level: 26
    Achievements:
    7 years registered
    Join Date
    Apr 2010
    Posts
    1,807
    Points
    11,798
    Level
    26
    Your observation is true.
    Unless it is operated in 1/16 or 1/32 microstepping mode , the movement cannot be less than a micrometer.
  5. #5
    Points: 13,519, Level: 27
    Join Date
    Nov 2012
    Posts
    2,519
    Points
    13,519
    Level
    27
    Quote Originally Posted by FvM View Post
    In my CD drive (LG, old defunct drive), the optical assembly is mounted between two permanent magnets and there are two sets of coils (four wires are seen). The beam can be rotated about y axis (assume that the stepper drive is the x axis) and also can be moved up and down (z axis) by manipulating the currents through these two coils.
    So I see that one drive (two magnets and two coils) is sufficient to tilt and move up and down. I am not sure about the polarities of the magnets, but I guess it is a quadrupolar setup (but I am often wrong).
