+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Member level 1
    Points: 1,694, Level: 9
    Achievements:
    7 years registered
    Join Date
    Aug 2009
    india
    Posts
    39
    Points
    1,694
    Level
    9
    Wrong BIOS installed in my laptop
    Hello
    I have installed wrong BIOS installed in my laptop, I tried to get all the BIOS files from Manufacturer website,
    since my laptop is not even trying to switch on & I am not sure how to go ahead loading correct BIOS.
    my question is :
    1) what ways i have to load correct bios since my laptop is not even switching on ? i see SPI chip on motherboard of my laptop & BIOS chip
    •   Alt2nd August 2016, 14:25
      advertising
  2. #2
    Advanced Member level 5
    Points: 34,278, Level: 45
    Achievements:
    7 years registered Created Blog entry Created Album pictures
    SunnySkyguy's Avatar
    Join Date
    Sep 2007
    Richmond Hill, ON, Canada
    Posts
    6,633
    Points
    34,278
    Level
    45
    Blog Entries
    7
    Re: Wrong BIOS installed in my laptop
    Can you enter BIOS setup?
    Is HDD toast? I.e. N.G. (click of death?, bad servo)
    DOES F11 or F? bring advanced recovery mode? repair or reinstall Windows?
    Not likely a BIOS problem.
    Anything on display? Did it get wet.?
    A good design question lists your overall requirements™ The best question deserves a better answer. ™
    ... Tony Stewart EE since 1975
  3. #3
    Member level 1
    Achievements:
    7 years registered
    Join Date
    Aug 2009
    india
    Posts
    39
    Points
    1,694
    Level
    9
    Hello,
    No, I cant enter in BIOS setup neither F11, F8 etc nothing seems to be responding, apart from few led's on motherboard.
    there was wrong bios loaded,
    •   Alt2nd August 2016, 18:38
      advertising
  4. #4
    Super Moderator
    Points: 28,167, Level: 40
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,441
    Points
    28,167
    Level
    40
    So you wrote an incompatible bios into your laptop?
    Well unless you have the information on the laptop for the details about what bios flash device they use and how to in circuit program it, then it's pretty much a big rectangular brick until you either learn this information about your laptop or have it worked on by a shop that can get/or_has that information.
    •   Alt3rd August 2016, 00:44
      advertising
  5. #5
    Newbie level 3
    Points: 19, Level: 1
    Join Date
    Aug 2016
    Posts
    Points
    19
    Level
    You can find the BIOS upgrade file from the motherboard manufacturer website. Download and run that program. In some situations you will have to use a boot disk or USB to run this
  6. #6
    Super Moderator
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,441
    Points
    28,167
    Level
    40
    If the OP already bricked their laptop by writing a bios that is not compatible with their laptop (so the laptop can't be powered up at all) having the correct upgrade won't do anything for them as the boot order on a PC is based on the boot code in the bios, which won't allow the laptop to boot. You can't boot a laptop with USB or via a boot disk (disregarding the fact that a large majority of new laptops don't even have a CD/DVD/BluRay disk drive) unless there is a valid bios.
    This is why all bios installation instructions come with something like...
    Do not reboot, power off, or unplug the laptop during installation....Only install on a laptop with a fully charged battery...etc.
  7. #7
    Super Moderator
    Points: 69,588, Level: 64
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Aberdyfi, West Wales, UK
    Posts
    11,375
    Points
    69,588
    Level
    64
    As far as I know, unlkess there is a protected boot block in the BIOS EEPROM, the only solution is to remove the IC and re-program it externally. I'm suprised there isn't a boot block you can activate, it would at least allow you to reprogram the BIOS even if it did nothing else. The trouble is there is no standard way to activate it. I would try switching on then repeatedly pressing one of the 'F' keys to see if it pops up a recovery message. You may have to try all the keys but make sure you switch off and then on between each key you try. If that doesn't work, try other keys, such as Esc, DEL, Home, insert and the cursor keys.
    Brian.
    PLEASE - no friends requests or private emails, I simply don't have time to reply to them all.
    It's better to share your questions and answers on Edaboard so we can all benefit from each others experiences.
  8. #8
    Super Moderator
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,441
    Points
    28,167
    Level
    40
    Quote Originally Posted by betwixt View Post
    Have you ever seen a laptop with one of those? I certainly haven't.
    •   Alt5th August 2016, 16:34
      advertising
  9. #9
    Super Moderator
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Posts
    11,375
    Points
    69,588
    Level
    64
    I think most of them have one. It contains the bootloader to allow new BIOS code to be installed. During the update, the normal BIOS can't be used so disk/usb functions don't work. The normal process of updating starts by erasing the old code so there must be some protected areas that are not erased for it to resume afterwards. As far as I'm aware, updates do not create a temporary BIOS in RAM. (like initramfs in Linux)
    I suppose it is possible that the wrong BIOS code is expecting a different type of EEPROM and the boot block area gets erased or overwritten by mistake.
    Even in laptops, it is common for the EEPROM to be in a socket so it should be possible to remove it and re-program it externally. The challenge would be to discover if the image needs decompressing and the address it loads into.
    Brian.
