what is the mechanism used for inter thread communication
bagavathi
Member level 3
Tamil Nadu,India
ipc mechanism is mainly for interprocess communication .for inter thread communication any mechanism is there?
What is inter thread communication have to do with FPGAs or other programmable logic (hardware)? The only hits on google deal with Java and other programming languages?
Explain your question and how it relates to FPGAs.
Put data where it can be accessed globally. Example, if you wish to pass the value of a variable, store it in a memory byte where the other thread (process, function) can access it. It is a workaround if you cannot pass the variable directly between the two functions.
