how to show this vector?
milan.km
Member level 3
hi
assume that I have 192 data(unsigned(7 downto 0), and I want to put them 64 of them into one vector with andices?
"a0" will be 0 to 63
"a1" will be 64 to 127
"a2" will be 128 to 191
because I want to write a for loop for a I want them to have their indices 0 to 2.
is there any way I could do this in vhdl?
srry for the english syntax error,english is not my native language.
will u please help me how could I write it?
thanks for answering
I meant like this :
I searched but I found just 1D1D arrays and 2D arrays. but I want two indices for rows,I am not sure it is possible in vhdl
the diagram you're showing is a 3d array and is perfectly doable in VHDL.
Code VHDL - [expand]
type a_element_t is array(0 to 63) of unsigned(7 downto 0);
type a_t is array(0 to 2) of a_element_t;
signal a : a_t;
did you really mean this.
PS. This isnt a true 3d array - its a 1D array of 1D arrays of 1D arrays.
signal a : a_t;
thanks for the answering.
yes I meant this.
would u plz help me how should I assign values to them,I wrote the following code, but it have some problems :
    for i in 0 to 2 loop
      for j in 0 to 63 loop
        a_var(i) := memory(63*i+j);  --error
      end loop;
    end loop;
thanks
Assuming you copied my declaration, the problem is that you're trying to treat a 3d array as if it were a 1D array.
What is "memory" and how is it declared? why are you trying to copy a whole chunk of it as if this were software?
why not post the whole code, not a snippet.
thanks for the answering TrickyDicky
here is the memory declaration :
type siz5 is array (0 to 192) of unsigned(7 downto 0);  --type of vector containing 5 img
signal memory : siz5 :=(others => "00000000");
here is the code :
process(clk,wr_ena)
variable addr : integer range 0 to s5 := 0;
variable a_var : a_tp := (others => (others => "00000000"));
variable i,j : integer ;
begin
IF (clk'event AND clk = '1') THEN
  if (wr_ena ='1') then
    memory(addr) <= p_in;
    addr :=addr+1;
    if (addr = s5) then
      wr_ena <= '0';
    end if;
  else
    for i in 0 to 11 loop
      for j in 0 to (s4-1) loop
        a := memory(s4*i+j);
      end loop;
    end loop;
  end if;
end if;
end process;
i have all the 3*64 unsigned values in memory and now i want to put each 64 of them in the on of parts of a.
yes, i dont know how to threat with 3d vectors and how to show the values of it.
Ok, apart from the missing declarations in your new code snippet (a, s4, s5) I really dont know what this code is trying to acheive. When wr_ena is '0', you're trying to copy the entire memory contents to some variable? This is not possible in hardware.
assuming a is supposed to be a_var, the problem is you're trying to assign the entire memory in a single assign, I think you meant:
for i in a'range loop
  for j in a(i)'range loop
    a(i)(j) := memory(i*a'length + j);
  end loop;
end loop;
