+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Advanced Member level 3
    Points: 4,693, Level: 16
    Join Date
    Feb 2012
    Posts
    806
    Points
    4,693
    Level
    16
    Why some DROs not oscillate withlout enclosure top covered, but others do?
    Some DROs not oscillating without metal plate placed above resonator. As i understand it is not frequency tuning (phase condition) problem, because moving resonator does not start oscillation. Although placing small metal piece above resonator instantly starts oscillation. What stands behind this? Less radiation because magnetic field lines stick to metal plate, or there still radiation exsists and it reflected back to resonator?
    •   Alt14th July 2015, 09:49
      advertising
  2. #2
    Advanced Member level 5
    Points: 33,056, Level: 44
    Join Date
    Dec 2004
    New England, USA
    Posts
    4,643
    Points
    33,056
    Level
    44
    Re: Why some DROs not oscillate withlout enclosure top covered, but others do?
    either the coupling is insufficient with the cover off, or the phase shift is wrong with the cover off
    1 members found this post helpful.
