+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Full Member level 4
    Points: 1,925, Level: 10
    Join Date
    Feb 2012
    Posts
    221
    Points
    1,925
    Level
    10
    how implement this switching power converter in MATLAB Simulink?
    hi.
    I have to simulate a "Non-Linear Carrier (NLC) Controller" in matlab simulink.
    in one part of my simulation, I have to simulate a "switching power converter" similar to the attachment.
    this converter "gives is(t) current" by using the "c(t) signal as it's driver".
    how implement this "switching power converter" in matlab simulink?
    c(t) (as input signal) and ideal is(t) (as output signal) waveforms are indicated in attachment.
    Click image for larger version.
    thanks a lot!
    •   Alt20th March 2015, 10:25
      advertising
  2. #2
    Super Moderator
    Points: 46,787, Level: 52
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    11,662
    Points
    46,787
    Level
    52
    Re: how implement this switching power converter in MATLAB Simulink?
    Are you describing a switched-coil converter?
    See the thread below. Three basic types are discussed: buck, boost, buck-boost.
    In my posts are links to tutorial simulations. These are interactive and animated, using Falstad's Java applet. (Your computer needs to have Java installed.)
    http://www.edaboard.com/thread268178.html
    •   Alt20th March 2015, 16:27
      advertising
  3. #3
    Full Member level 4
    Join Date
    Feb 2012
    Posts
    221
    Points
    1,925
    Level
    10
    I have little knowledge about switching power converters.
    I want to simulate above attachment in matlab simulink.
    How do i have to it?
    Is there anyone who can give me its matlab file?
    •   Alt20th March 2015, 20:03
      advertising
  4. #4
    Newbie level 3
    Points: 32, Level: 1
    Join Date
    Aug 2015
    Posts
    Points
    32
    Level
    You could either (1) build your own model in simulink by means of existing blocks or (2) model the circuit by means of differential equations (ODE's).
    (1) This would be typically done in the Laplace domain. However, if the power circuit contains many electrical components, this modelling approach becomes tedious.
    (2) In this case the circuit is described as a system of linear equations. The equations depend on the states of the switches and diodes in your model, so the ODE's dynamically change during operation. Again the complexity depends on the number of components in the power circuit. Some commercial tools are available (e.g. SimPowerSystems, Sentrix,...) that apply this approach.
