[SOLVED] Can't create smybol with verilog-a code in cadence
zongya
Newbie level 5
Hi all,
I just start to learn verilog-a and want to create a voltage-controlled current source(vccs) in cadence virtuoso. I learned that cadence would check my syntax automatically and create the symbol if the code is OK. However, when I open a new cellview in verilog-a, I can't save the code, so I can't convert the code to symbol...
When I open the veriloga file it is like this -
Is it because I can open it with only "Read Veriloga"? When I create a new veriloga cellview, the only option is "Read verilog-a".
How can I edit and save the file? help...And thanks in advance!
UPDATE:
I found when I tried to open verilog-a, it showed me "*WARNING* (icLic-3) Could not get license Virtuoso_Schematic_Editor_L". But when I open a schematic cellview, it showed me the same warning and then "*INFO* (icLic-25) License Virtuoso_Schematic_Editor_XL ("95115") was used to run Schematics L."
That means I have license for Editor_XL. How can I tell cadence to open verilog-a with Editor_XL, not Editor_L?
I google it and found a post said
put it like this into your .cdsinit :
envSetVal("license" "VSELicenseCheckoutOrder" 'string "XL,L")
I opened .cdsinit file and it has many lines...where should i put this additional line??
UPDATE:
Problem solved. Just use <editor = "gedit"> in CIW without brackets, and reopen the veriloga cellview again... "gedit" can be any editor you like...
