LED DIY Luminaires using Series Power LEDS and parallel Arrays on wire distribution,
D.A.(Tony)Stewart
Advanced Member level 7
Richmond Hill, ON, Canada
I started a blog https://www.edaboard.com/blog/1946/ of home lighting using common wall powered LEDs using unregulated, regulated and modified adjustable Laptop Chargers.
CREE 1~3W LEDs can be used in series to match the supply voltage and parallel arrays on a string of wire to distribute. Thermal runaway avoidance is satisfied but I did not discuss the relationships of low Thermal resistance , low ESR and Shockley Effect of voltage drop. from temperature rise is understood but not discussed. Feel free to add questions in the blog.
Ultimately I feel the home of the future should include centralized +/-24 or 48V distributed power for DC LED lighting, eliminations of all the little bricks we use for peripherals and many other things.
All these projects cost me very little to make.
